Replacing the IQ Mini Door / Window Sensor Battery
The IQ Mini door / window sensor requires two CR2032 batteries.
Insert a coin in the slot and twist gently to remove the cover.
Note: If a coin is not available, insert a small flat-head screwdriver into the side slot of the plastic cover and twist to open each side.
Remove the old CR2032 batteries by sliding them out from the side.
Image of the IQ Windor / Door Sensor
Insert the new CR2032 batteries.
Note: The + should be facing up.
Snap the cover into place and ensure it is closed securely to avoid any tamper notifications.
Note: After replacing the battery, the system may take up to five minutes to clear the low battery warning message.
