The PowerG door / window sensor requires one CR2450 battery.
Insert a coin in the slot and twist gently to remove the cover.
Note: If a coin is not available, insert a small flat-head screwdriver into the side slot of the plastic cover and twist to open each side.
To remove the battery, wedge a flat-head screwdriver under the battery, and then twist the screwdriver using the base as a lever.
Insert the CR2450 battery at an angle and press down on the battery until it fits into place.
Note: The writing on the battery should be facing up.
Snap the cover into place and ensure it is closed securely to avoid any tamper notifications.
