Replacing the PowerG Wireless Motion Sensor Battery
The PowerG wireless motion sensor requires one CR123A battery.
Complete the following steps to remove the cover.
  1. Using your thumb, lift the screw cover upward.
    Image of removing the PowerG motion sensor screw cover
  2. Using a screwdriver, remove the screw.
    Image of replacing the PowerG motion sensor cover screw
  3. Insert the screwdriver into the slot and then push down to separate the base from the cover.
    Image of removing the PowerG motion sensor cover
Remove the existing battery and insert the new CR123A battery while observing polarity.
Image of replacing the PowerG motion sensor battery
Complete the following steps to replace the cover.
  1. Close the cover and tighten the screw.
  2. Close the screw cover with your thumb.
