On the Cox remote, press MENU to open the Cox menu.
Use the down arrow to highlight Settings and then press the right arrow.
Result: The Settings menu displays.
Use the down arrow to highlight Audio & Video and then press the right arrow.
Use the down arrow to highlight Audio Settings and then press the right arrow.
Use the table below to determine which audio setting to select.
Audio Settings | Options |
Volume Level | Volume Level enables or disables the ability of the Cox Remote to adjust the volume on the TV.
Analog Output | Analog Output controls the audio output sent to your TV from the receiver.
Digital Output | Digital Output is used to enable sound through an optical jack.
Dynamic Range | Dynamic Range is the difference between the quietest and loudest volume in a stream. In modern recording, this range is often limited through dynamic range compression, which allows for louder volume, but can make the recording sound less exciting or live.
Audio Language | Audio Language selects the audio language for programs that carry both the primary language and Secondary Audio Programming (SAP).
