Setting up a Power Over Ethernet Injector
Use the following steps to setup a Power over Ethernet (PoE) injector.
Connect the power adapter to the PoE injector and plug the other end into the wall outlet.
Connect one of the Ethernet cables to an active port on your router, firewall, or LAN switch and to the LAN port on the PoE injector.
Connect another Ethernet cable to the handset and to the PoE port on the PoE injector.
