See the table below for solutions to common Ethernet connectivity issues.
Problem | Solution |
Broadband Connection Failure | Check that the cable modem is inserted into the WAN port on the router and that the cable modem is connected. |
No Connectivity to the Touchscreen | Check that the Ethernet cable for the touchscreen is inserted into one of the four ports on the router. |
Intermittent Connectivity |
