See the table below for solutions to common problems with WiFi Connection Problems.
Problem | Solution |
WiFi Connectivity Failure or Intermittent Connectivity | Range or interference issues may be the cause.
Poor or No Signal Strength | Range or interference issues may be the cause. Relocate the device and check for signal. |
No Connectivity to the Touchscreen | Check that the cord for the cable modem is inserted into the router's Internet Port and that the cable modem is connected and powered on. |
WiFi SSID / Password change | Complete the following steps to update your SSID/Password on the touchscreen.
