Using Speed Calling
You may enter up to 38 telephone numbers, local or long distance, into your Speed Calling list. You can then dial those numbers by dialing just a one or two-digit code followed by the # symbol. The numbers will be assigned a code of 2 to 9 or 20 to 49.
Create a Speed Calling List
Follow the steps below to create your Speed Calling list.
  • Complete the following steps.
    1. Make a list of numbers that you frequently dial.
    2. Assign each number a speed dial code:
      • For Speed Dial 8, use 2 - 9.
      • For Speed Dial 100, use 20 - 49.
      Note: Numbers 10 - 19 cannot be used for Speed Calling.
  1. Lift the handset and dial *74 for Speed Dial 8 or *75 for Speed Dial 100.
  2. Listen for the dial tone.
  1. Dial the speed dial code assigned to the number you want to store.
  2. Dial the phone number associated with the speed dial code.
    Note
    : For long distance calls, add the 1 and the area code.
  1. Press #.
  2. Listen for the confirmation tone.
    Note
    : Once you have the list created, to call someone on the Speed Calling list, dial the assigned one or two-digit code, then press #.
Edit Speed Calling List
Follow the steps below to edit your Speed Calling list.
Lift the handset and listen for the dial tone.
  1. Press *74 for Speed Dial 8 or *75 for Speed Dial 100.
Dial the speed dial code you want to change
  1. Listen for the cancellation tone.
  2. Follow steps 3 and 4 for Creating a Speed Calling List to reprogram your speed dial code.
