Refer to the following tabs to learn more about the Cradlepoint LTE Device lights and signal meanings.
The Cradlepoint must be powered using an approved 54 VDC power source. Battery usage will power the endpoint but for a limited time.
Refer to the following table for information about the Cox Business Net Assurance Cradlepoint LTE Device lights.
Light | Meaning |
No Light![]() | If you are not receiving power, check the power switch and source connection, insert the charged battery, or check the power switch. |
Green![]() | It is powered on. |
Blinking Green![]() | The battery powers it. |
Yellow![]() | Attention is needed. Log into NCM and use the Remote Connect menu to access the router's NCOS and manage the alert. |
Blinking Yellow![]() | Replace the battery; the installed battery can only hold 60% or less of its original capacity. |
Refer to the following table for information about the Cox Business Net Assurance Cradlepoint LTE Device signals.
Signal | Meaning |
Signal Strength![]() | LED bars indicate the active modem's signal strength. |
No Lights![]() | No Signal |
Four Solid Bars![]() | Strongest signal. |
One Blinking Bar![]() | The weakest signal, a blinking bar, indicates half a bar. |
Four Blinking Bars![]() | The SIM door is not installed, and the modem is off. |
Embedded Modem![]() | Indicates the connect status for the internal modem. |
No Light![]() | The modem is not connected; it is manually disconnected. |
Solid Green![]() | The modem has established an active WAN connection. |
Blinking Green![]() | The modem is connecting. |
Solid Yellow![]() | The modem is not active. |
Blinking Yellow![]() | Data connection error. No modem connection is possible. |
Blinking Red![]() | The modem is in the process of resetting. |
